Re: 10-20 mccormick deering
Posted by Bob Kerr on February 06, 2009 at 18:29:30 from (216.249.67.127):
In Reply to: Re: 10-20 mccormick deering posted by DAN DOYLE on February 06, 2009 at 17:38:33:
Mine was stuck like that too, I cleaned up the pistons , honed a little with the stone type hone and put in new rings, worked fine, But my piston pins were a bit loose and couldn't find new so used the best used ones I could get.
