Re: Motor Generator Charging Less As RPMs Increase
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by probably not on April 05, 2000 at 20:44:17 from (167.142.17.8):
In Reply to: Motor Generator Charging Less As RPMs Increase posted by AgMan on April 05, 2000 at 10:46:11:
AgMan- Sir! Is hard telling what is going on from the info you tell. "Under-cutting" the armature was/is common practice. Along with it needs to be "turning the armature", where the commutator bar surfaces are all cut concentric with the armature's axis of rotation. If let go the "brush bounce" will eventually burn up the armature. Look inside and see if you got arcing as RPM increases. If so, get the commutator turned. If not, check the 12 volt conversion posts archives. Good luck, IHank
Post A Followup
: Re: Re: Motor Generator Charging Less As RPMs Increase
