Re: PTO seasonal disconnect
Posted by nosih on February 07, 2009 at 12:06:40 from (71.82.219.37):
In Reply to: PTO seasonal disconnect posted by SDE on February 07, 2009 at 11:12:54:
The tractor would need to be split to make the change. There is a coupling held on with a roll pin on PTO drive shaft in the clutch housing, and the other end of this coupling attaches to the shaft in the trans housing. You would need to replace the existing coupling with one that has the groove that accepts the seasonal disconnect lever.
