Re: CRRAACCKK follow up #2
Posted by Hugh MacKay on February 07, 2009 at 16:12:06 from (209.226.247.125):
In Reply to: CRRAACCKK follow up #2 posted by Vern on February 07, 2009 at 15:17:00:
Vern: Your splitting at front of transmission, not at clutch housing, correct? I'd put blocking under U type drawbar, and drill holes in a couple of angle irons to make leg up from floor to threaded drawbar holes at front of final drives. I'd get that blade off, you could find yourself removing those final drives before your done.
