Re: Help Please!
Posted by Michael Soldan on February 07, 2009 at 16:36:47 from (24.235.41.171):
In Reply to: Help Please! posted by Jack Boughner on February 07, 2009 at 14:02:52:
Our 584 has sometimes not gone into gear when shifted thusly..some lubricant on the shifting levers underneath the deck they are mounted on and suddenly it shifts well agin..you aren't giving us much to go on, its either not going into gear or range or the clutch is totally done,I'm thinking it is not in either high or low range or it is not shifted into gear even if the gearshift indicates it is.
