Re: Super C Fan Assembly Problem
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Larry24d on April 06, 2000 at 03:37:11 from (209.242.110.109):
In Reply to: Super C Fan Assembly Problem posted by Andrew on April 05, 2000 at 19:42:39:
I'm guessing that you don't have the large washer on your fan hub shaft, and thats letting the pulley get drawn into the fan hub mounting. Is this possible?? I know that the one I have has 2 larger washers on it, one for the front (towards the radiator)and one for the back (towards the engine). Let me know what you find out...I'm curious. I would have thought that you'd have noticed that the pulley was rubbing though, when you mounted it. If this don't help let me know and I'll go look at mine and let you know how the shaft is made...
Post A Followup
: Re: Re: Super C Fan Assembly Problem
