H still not right
Posted by redplower159 on February 07, 2009 at 17:54:00 from (69.72.101.238):
Hi there. Have timed my H like yall replied to in the post. Like i said i have that ing. box from petronix. When trying to start the H i pulled the #1spark plug and wire and grounded to the frame. With the key on if i jiggle the hot wire to the coil from the switch there is a spark from the plug even if it is not at #1 on the didt can be at #2 and still fires??? Is that right or is something messing up. I say jiggle the wire just trying to see if something works( I HAVE NO LOOSE CONNECTIONS)
