Re: IH 504 with Loader -- Value? -- Pictures enclosed.
Posted by karl f on February 07, 2009 at 22:24:08 from (172.129.101.173):
In Reply to: IH 504 with Loader -- Value? -- Pictures enclosed. posted by Ray Wilson on February 07, 2009 at 16:10:22:
Make sure you identify it is a TA or a reverser. Either way would be ok, just know what you're buying and how to use. try out in low gear first if not sure. although the shift won't go into reverse if you have a reverser. Could you imagine the results if you pulled the lever back thinking it was a TA in Road gear? at least if you're using proper TA methods you'd only pull it back starting out...
From the picture i think it is a TA.
karl f
