Re: 1066 cab noise
Posted by IaGary on February 08, 2009 at 07:18:49 from (207.177.17.200):
In Reply to: 1066 cab noise posted by Randy2 on February 08, 2009 at 04:52:28:
You bet, put that foam on everything you can.
Hit the floor and around the dash with a double layer.
Gary
