Open the fuel lever at the strainer bowl. Then remove the low level plug on bottom of carb. Fuel should run out in a few seconds. If it keeps on draining it is a needle valve stuck open. This could be the result of a float that has a hole in it and is full of fuel, or badly set float. You can inspect the float, and set it by removing just the bottom bowl. If you are blowing liquid gas out of the manifold you have to solve the excess fuel problem first. I don't think your M would go from a purring kitten to a non runner because of a sudden valve train problem.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
