Re: flywheel starter ring
Posted by Hugh MacKay on February 08, 2009 at 11:28:47 from (209.226.247.189):
In Reply to: flywheel starter ring posted by Joe the tractor guy on February 08, 2009 at 10:25:24:
Joe: What is normal wear. Quite different for the guy that starts once or twice and works the tractor all day, compared to the guy the starts his tractor 25 times per day. A starter only works when starting the tractor, same as a gear shift only works when shifting gears. It was quite common to wear a shift lever every 5 years on a loader tractor, probably shifts 100 times for every time a field tractor shifts gears.
I doubt if this is the first time your Super A ring gear has been changed, probably not the second time either. These tractors are pushing 60 years old. From experience with working tractors, ring gear every 12 to 20 years, depending on operator habit.
Definitely do as Jim said, throw that Bendix in the garbage, buy a clutch type starter drive.
