Re: more fuel
Posted by pete 23 on February 08, 2009 at 11:54:36 from (173.87.1.12):
In Reply to: more fuel posted by LIVIN LUCKY on February 08, 2009 at 10:59:14:
There is a torque screw on rear or back side of injection pump depending on vintage of pump. This will most likely do very little or nothing but you can try turning it out a half turn or so. The main adjustment is of the leaf spring controlling the maximum movement of the pumping plunger inside and requires some dissassembling of the pump. Have to remove cover, metering valve guide stud and governor linkage. Then turn engine to see allen screw on leaf spring and turn it in a tad. Like maybe a quarter turn max.Then on reassembly, the automatic load advance will need to be adjusted. Not a job to be taken lightly as a runnaway engine could result. You may have low fuel pressure due to worn primary pump or regulator valve so the pressure should be checked before any adjustments are made. I will assume fuel filters and flow through hose at pump are good.
