Re: NEED 1945 FARMALL M TRANSMISSION SPECS
Posted by Janicholson on February 08, 2009 at 15:18:21 from (64.83.193.190):
In Reply to: NEED 1945 FARMALL M TRANSMISSION SPECS posted by Patrick Coleman on February 08, 2009 at 14:59:51:
I teach University classes so the data here is what I would tell the engineers I work with.
There are several transmission options available for Ms. Thus count the constant mesh gear teeth drive and driven, the counter shaft gears for the 4 gears of reduction, and the differential ratio at the pinion/ring. Then factor in the bull gears and pinions ratio in the finals. At the age of the tractor, there may be no other way of assuring the correct answer. You could also take out the plugs and turn the engine in each gear watching the rear axle on one side to calculations, and get close. caseih.com look for parts and service at the top of the splash page, and then start your search her, on the second page. Put in Farmall on the blank box.
Go to M. Select transmission. Very cool content there. JimN
