Re: International Harvester 544 gas won't start
Posted by Janicholson on February 08, 2009 at 16:13:50 from (64.83.193.190):
In Reply to: International Harvester 544 gas won't start posted by c w cunningham on February 08, 2009 at 15:10:32:
Make sure the fuel is getting to the carb! not just pumping.
See if it is timed correctly
Make sure the manifold and carb are not loose or have air leaks to the outside.
Check the fuel soleinod mentioned below for action with the key.
Check the compression.
JimN
