In other words, rotate the trans input shaft by hand, counting, to produce 1 rev of the output shaft.
Regarding efficiency, I'm told that a ring & pinion setup has approx 10% efficiency penalty over a parallel shaft arrangement due to the high sliding friction on the gear faces. Although I have not done my own personal measurements.
To be sure the entire transmission assembly has both parallel shafts and a ring & pinion in it. Arriving at the efficiency empirically would be a trick using a lot of expensive instrumentation.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
