Posted by ScottyHOMEy on February 08, 2009 at 19:17:24 from (71.241.192.17):
In Reply to: flywheel starter ring posted by Joe the tractor guy on February 08, 2009 at 10:25:24:
All good advice below.
An engine will come to rest when shut down when the last two unfueled cylinders find a balance between compresion and exhaust. On an inline four-cylinder that means that the next time it's started, the starter gear will bite within two fairly narrow ranges on the ring gear, and you will see the wear in two spots pretty much opposite each other.
Replace the ring gear and go with the new-style clutch-type starter, and the whole rigging will outlive you.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
