If I'm understanding you, your lights aren't made to gorund through their bodies and there are two wires to each light, a hot and a ground. If that's the case you can ground about anywhere inside the steering support. I'd tie the ends of my ground wires together on a 3/8" eyelet and ground it to either one of the bolts holding the shaft support to the panel box or, better yet if you have enough wire, to one of the bolts holding the panel box to the chassis. Clean everything up so you get a good connection and your lock washer should bite into that eyelet to give you a good connection.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
