Re: 1948 Cub PTO
Posted by Bigdog on February 09, 2009 at 07:51:22 from (71.64.18.18):
In Reply to: 1948 Cub PTO posted by Farmall Ed on February 09, 2009 at 07:46:51:
How much engagement of the shift collar and shaft do you have? If the collar is barely engaging the shaft check the pin on the lever that fits into the collar. If it is worn badly it should be replaced. Another thing you can do to increase engagement is to slot the mounting holes on the quadrant so the lever can be moved further.
