First off check to make sure you have power in the ignition side of the coil. If you do then check yours points and make sure they are clean and you get a spark from them when you open and close them by hand. Bad points can cause that same problem or even a bad condenser
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
