Posted by Janicholson on February 09, 2009 at 15:42:46 from (199.17.6.128):
In Reply to: Farmall M w/ a miss posted by Spark! on February 09, 2009 at 14:42:39:
If you unhook the wire from the plug, and put a different plug on the wire, ground the different plug, then crank it up and run it, does that plug fire? If it does, I would do a compression check on that cylinder. If it does not, one of the things you changes was not good! It could be a stuck valve. or a burnt valve, or a broken valve spring, or other issue. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
