Re: Farmall M w/ a miss
Posted by Brownie 450 on February 09, 2009 at 15:46:37 from (216.51.158.151):
In Reply to: Farmall M w/ a miss posted by Spark! on February 09, 2009 at 14:42:39:
Try taking a compression test on all the cylinders. I'll bet #2 is low on compression or has other problems---valve hanging up--burned valve--could even be an intake gasket leak on #2 side of the #1 &2 intake gasket. If you remove the valve cover, have a good look around---could be something like a broken rocker arm or a pushrod jumped out of its' socket.
