Re: 1456 alternator light stays on
Posted by Allan In NE on February 09, 2009 at 16:53:52 from (148.78.243.24):
In Reply to: 1456 alternator light stays on posted by joe 1971 on February 09, 2009 at 16:28:30:
Assuming that this system has the original external voltage regulator?
That blue wire on the square plug feeds 12 volts to the light from the alternator end when charging for the purpose of shutting the light off (voltage applied to both ends of the bulb filament = 0 current flow and no light).
If that terminal is grounded inside the alternator (as in a diode blown allowing a back trickle to ground), the light will stay on even tho the alternator chages just fine.
I'd sure check the diodes in the diode trio; betcha one of 'em is leaking.
Allan
