If you can pull the new wire in using the old wire being pulled out. If there is no wire, use a piece of electric fence wire or # 12 solid copper and push it in from the outside end. It has to be relatively straight. Tape the end of the #16 stranded light wire to the end and pull it back out. You probably will not be able to push a #16 stranded through the pipe. Electritians have a special flat wire puller made of spring steel with a built in hook in the end. If you can get you hands on one of those it will work best.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
