Posted by burnsg2003 on February 09, 2009 at 19:13:19 from (205.188.116.73):
I have a 1953 SH. When I take the brake housing off I see I am getting oil on the disc brake. It seem to be leaking from the splined shaft that the disc slides on. Is there a seal and how do you replace it. Also, if there is a seal do you have to get into the transmission to fix it. Any help would be appreciated. Also, there are is a linkage on each brake with pins at each end mine are worn out where can I find these at.
Today's Featured Article - New Hitches For Your Old Tractor - by Chris Pratt. For this article, we are going to make the irrational and unlikely assumption that you purchased an older tractor that is in tip top shape and needs no immediate repairs other than an oil change and a good bath. To the newcomer planning to restore the machine, this means you have everything you need for the moment (something to sit in the shop and just look at for awhile while you read the books). To the newcomer that wants to get out and use the machine for field work, you may have already hit a major roadblock. That is the dreaded "proprietary hitch". With the exception of the
... [Read Article]
Latest Ad:
[More Ads]
