Re: 1948 Farmall H bearing by my brakes
Posted by burnsg2003 on February 09, 2009 at 19:17:30 from (205.188.116.73):
In Reply to: 1948 Farmall H bearing by my brakes posted by narrowfarm on February 09, 2009 at 19:00:16:
I do not know the name of the bearing. The gear shift will raise straight off with the top plate. The gear shift is attached to a shifitng fork. Just make sure that before removing you know what gear the tractor is in and do not move any of the shifting gears. When you pu the plate back on just make sure the shifter is in the same position as when it cam off. If you move anything you may have problems.
