Posted by Mike Farmer on February 10, 2009 at 01:22:50 from (86.31.88.219):
In Reply to: Setting Valve Lash posted by Red Rookie on February 09, 2009 at 19:29:46:
I use the "9" method as follows. Remove Spark plugs. Turn the engine over until No1 valve is fully open Adjust No 8. Simple 1+8=9
V Open--V adjust
1-----------8 2-----------7 3-----------6 4-----------5 5-----------4 6-----------3 7-----------2 8-----------1 It really is that simple and is doesn't matter which end you call No1 as long as you keep going in the same direction. Set 020 cold and when you check it hot it will probably be near enough 017. that you may not need to readjust. MTF
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
