Posted by Brownie 450 on February 10, 2009 at 04:49:36 from (216.51.158.151):
In Reply to: Farmall M w/ a miss posted by Spark! on February 09, 2009 at 14:42:39:
Since you have swapped out plugs--wire--the only thing left is the #2 plug wire terminal on the distributor cap is getting grounded out inside of the cap---but how?? Is the bakelite dust shield under the cap clean & in good shape?? There surely can't be a grounding issue with the spark plug threading into the head?? Are you checking the spark with a different plug held up against the block [ground]?? I had a brand new Champion plug that was grounded internally & couldn't get a spark through it. I'd stick a small screwdriver in the #2 hole on the distributor cap & hold on tight to see how much voltage --if any-- you are getting, while it is running. There has to be a reason that the #2 isn't getting spark.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
