Posted by pete 23 on February 10, 2009 at 10:25:18 from (173.87.1.12):
In Reply to: farmall 300 hydraulics posted by E. Hanson on February 09, 2009 at 17:10:46:
You are dealing with a spool valve and there is no positive seal as they need clearance to operate.There is no o-ring in the valve that hold the load. Wear over the years allows more leakage past the lands. Make sure though that it is not the cylinder leaking as a leaking cyl will cause pressue to equalize onto the rod side of cyl and about quadruple the pressure making it impossible for spool valve to hold up very long. You can add a single action check block or altelrnating check valve and this will positively hold the load up.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
