About 6 months ago I did an A for a neighbor. I lifted the weight of the tractor off the front axle, removed the axle pivot shaft. with the front axle resting on jack stands I was able to lift the front of the tractor further up. remove the tie rods. there are about 6-8 bolts going up through the bottom of the base of the steering box. remove the bolt in pt arm and remove the base and arm together. I put seals and a new base gasket in because they were leaking bad. I found that the sloop in the pt shaft was because of wear on the clamping bolt. One new grade 8 bolt and locking nut sloop gone. I hope this helps
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
