Put it in the oven and heat it to about 300 degrees. Make sure its clean so there's no oil or grease. Use heavy oven mittens to handle it and don't waste time installing it. Be sure to leave the cam gear cover bolts loose until its installed. Make sure there's no groove worn into the pulley's hub from the old seal. Here's what Greg made for installing his pulley. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
