Re: 454 lacks power
Posted by the tractor vet on February 10, 2009 at 13:42:22 from (76.212.226.84):
In Reply to: 454 lacks power posted by nosoup4u on February 10, 2009 at 13:22:49:
Yea ya got a carb problem . There is dirt in the passages and not allowing the fuel to flow like it should . If you are the one doing the carb then pull it and set down at the bench and study it and put your glasses on and look at all the little holes get yourself a torch tip cleaner and a bucket of real carb cleaner and take it all apart and soak it for several hours , then rinse it in HOT water and start the blow drying along with running the tip cleaner thru all the little holes just don't force it and break one off in the hole then blow it out several more times . Also check and make sure that ya have a full stream of fuel coming out of the fuel line as there also maybe a blockage in the tank.
