Re: Where to Jack
Posted by Hugh MacKay on February 10, 2009 at 15:38:08 from (209.226.106.137):
In Reply to: Where to Jack posted by Tom in Iowa City on February 10, 2009 at 14:20:25:
Tom If you just want to remove wheels, jack under drawbar. Those spots you mention are necessary if you want to remove a final drive.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
