Re: Setting Valve Lash
Posted by El Toro on February 10, 2009 at 16:46:09 from (64.12.116.73):
In Reply to: Setting Valve Lash posted by Red Rookie on February 09, 2009 at 19:29:46:
With No1 piston at TDC on the compression stroke you adjust valves starting from the radiator.
Adjust valves 1,2,3 &5 then rotate engine until No4 piston is at tdc which should be one full turn. Then adjust 4, 6, 7, & 8. Set them all at .020" cold . Hal
