Posted by Red Mist on February 10, 2009 at 17:12:07 from (72.171.0.142):
In Reply to: Setting Valve Lash posted by Janicholson on February 09, 2009 at 19:29:46:
El Toro said: (quoted from post at 17:46:09 02/10/09) With No1 piston at TDC on the compression stroke you adjust valves starting from the radiator.
Adjust valves 1,2,3 &5 then rotate engine until No4 piston is at tdc which should be one full turn. Then adjust 4, 6, 7, & 8. Set them all at .020" cold . Hal
Good call, Hal. Right out of the IH GSS-1356 Tune-up specs manual. It is easy and it sure works well.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
