Re: Farmall A Crank pully reinstallation
Posted by P and R Pete on February 10, 2009 at 18:51:37 from (173.86.13.126):
In Reply to: Farmall A Crank pully reinstallation posted by doggonetractors on February 10, 2009 at 10:18:45:
Scotty, LOL!
I heated mine to 200 degrees, and same deal, used oven mitts, had the door open, and ran like a fool to the shop. I also was careful to have no witnesses!
I had my crank cleaned and reground by my machinist, and the pulley had also been cleaned because a small crack on an outer edge needed to be welded, so they both were spotlessly clean.
I used this rig with a bottle jack...
third party image
...and my pulley slid on smooth as butter, but I'm not saying it's the way to go, as you don't want to do any damage to the rear thrust bearing. Scotty's way, pulling it on with threaded rod in the crank end, puts no stress on the bearing whatsoever.
