Re: Tire brand question
Posted by 504-2 on February 10, 2009 at 19:57:01 from (216.145.144.254):
In Reply to: Tire brand question posted by Randy-IA on February 10, 2009 at 18:59:07:
Just go with a local dealer, if you have a problem they will be there to help,.com wont be. Just a note on tires, if you will buy a container load, you can have YOUR NAME put on the side of a tire.
