Re: IH 282 info needed
Posted by Owen Aaland on February 11, 2009 at 05:22:01 from (65.165.246.48):
In Reply to: IH 282 info needed posted by Pete76NY on February 10, 2009 at 14:19:02:
bc said: (quoted from post at 20:20:11 02/10/09) Thanks gearnut. We were talking on another thread about the 221 gas and the 263 gas using the same short block. Are you saying that the same short block is also used for the 301 gas as well as the diesels? Does the 263 use a sleeve and the 221 use a thicker sleeve than the 263? Is that how it works?
Thanks.
The blocks are the same, not the short blocks which would include all the other parts internal to the block.
The C212 uses a crankshaft with a shorter stroke than the C263. This difference is compensated for by moving the piston pin hole lower in the piston for the C221. The sleeve is the same for both engines.
The C263, C291, and C301 all share the same crankshaft. The blocks are bored different to accept larger sleeves in the C291 or no sleeves in the 301.
