Re: Farmall H trans deck removal. 1948 H
Posted by GeneMO on February 11, 2009 at 07:02:58 from (65.174.132.27):
In Reply to: Farmall H trans deck removal. 1948 H posted by narrowfarm on February 10, 2009 at 11:49:26:
Can you lower the front and just leave about a quarter inch spacer or something to hold it up a little. Then put a little pressure from below, like a bottle jack and length of 4X4. With pressure on it, jolt it a little with the deadblow hammer. If you can ever get an old screw driver or two driven in. If you are careful you should not hurt the surface. Then progress up to a cold chisel. Sounds like that one bolt may be swelled up a little. Patience and working it a little at a time. May have to take it up, little penetrating oil around the troublesome bolt, then take it back down. back and forth.
Good luck,, Gene
