Re: Charging Battery on Super C
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Bob M on April 06, 2000 at 11:51:16 from (192.232.120.194):
In Reply to: Charging Battery on Super C posted by Paul on April 06, 2000 at 10:06:00:
Paul - Just remember to hook positive to positive, negative to negative, like the Red says. Applies both to connecting a battery charger and to jumping.
Not recommended to jump 6 volts off of 12. But if you gotta, here's how (assume now you have a 6 volt positive ground tractor to be jumped):
1 - VERY IMPORTANT!!!! Make sure the two machines are NOT touching each other. And wear safety glasses.
2 - Hook one jumper cable to a good ground on the 12 volt machine, and to the battery cable connection on the 6 volt machine's starter switch. Don't hook to the battery!
3 - Take the other other jumper and hook one end to the 12 volt machine's battery positive terminal. Finally hook the other end of the jumper to the frame on the 6 volt machine (expect a spark when you do...) Immediately crank the 6 volt machine, then disconnect one of the jumpers at the 6 volt end the moment it starts.
Be careful - never make the last connection at a battery! Otherwise the spark occurring when you complete the circuit can cause a battery to explode. It's unlikely, but the consequences are severe! (Been there...)
Post A Followup
: Re: Re: Charging Battery on Super C
