Re: 53 Super M Will Not Start
Posted by Bob M on February 11, 2009 at 10:12:33 from (151.190.254.108):
In Reply to: Re: 53 Super M Will Not Start posted by Scott Dobbins on February 11, 2009 at 09:48:23:
Sound like it's jumped time on account of a broken cam gear. (It's not unusual problem for the Stage II Super M, 400 and 450 with the live pump.)
Quick check: Turn the crank until the TDC mark on the front pulley aligns with the pointer on the gear cover. Then remove the distributor cap and mark on the body where the rotor is pointing.
Now unbolt the hydraulic pump/distributor assembly and pull it back away from the mounting plate (you can leave the hyd hoses attached). Inside you will see the cam drive gear inside the gearcase. Reach in with your fingers or a large screwdriver and try to move the cam gear forward/back. If there's ANY movement whatsoever it's a sure sign the gear hub has busted.
Replacing the cam gear is straightforward and not terribly expensive - a new gear is about $150 or so. However some large and heavy parts (ie. the entire front end) must be removed to get at it.
Today's Featured Article - A Tractor's Point of View - by John Manley. I began my life on August 3,1941. I was actually built at different times and days but I was officially an M Farmall on August 3.I was real nice and shiny. That’s me, in the old picture, third from the left. I was loaded on that train and sent to a little town in South Carolina. I didn’t get to see much of that town. I was moved off the train fast and on to the dealer’s ... [Read Article]
