Re: 53 Super M Will Not Start
Posted by D Slater on February 11, 2009 at 11:32:41 from (71.164.44.184):
In Reply to: 53 Super M Will Not Start posted by Scott Dobbins on February 11, 2009 at 09:16:29:
Start simple, does it have good spark, still at the correct time. Look at plugs, do they show gas or dry. Remove pipe and hold hand over carburetor inlet while cranking. If it sucks agian your hand the cam and valves are probably working. If it builds oil pressure while cranking the cam is turning back to oil pump. If the fire timing and fuel checks okay, run a compression check then go into engine if needed.
Today's Featured Article - A Tractor's Point of View - by John Manley. I began my life on August 3,1941. I was actually built at different times and days but I was officially an M Farmall on August 3.I was real nice and shiny. That’s me, in the old picture, third from the left. I was loaded on that train and sent to a little town in South Carolina. I didn’t get to see much of that town. I was moved off the train fast and on to the dealer’s ... [Read Article]
