Re: farmall c wiring
Posted by wkfarmall on February 11, 2009 at 22:58:22 from (193.18.92.131):
In Reply to: farmall c wiring posted by wkfarmall on February 10, 2009 at 22:44:13:
Thanks for all the help guys. I believe I originally had a mag, but the tractor now has the upright distributor, 4 pos. switch, cut out relay. It is a 49 model, with oversize breather, distilate manifold, distilate carb, shutters, and starting fuel tank. The dist. sits upright and does not look to be original. The wiring was all butchered up and I have restored the tractor all but getting the wiring correct. Randy how can I find your e-mail address. Again thanks to everyone for your help and I will keep you posted on how it turns out.
I have a 52 Super A and I completly rewired it using a diagram from the case/ih site and everything worked out perfect.
Will probably have alot of f-20 questions also.
