Re: C vs. B engine
Posted by gene bender on February 12, 2009 at 01:32:43 from (67.55.226.75):
In Reply to: C vs. B engine posted by Ronnie Langford on February 11, 2009 at 17:22:33:
Both are 113 cu in. The B does not have the place for the hy pump. They are interchangeable. But if you want the hy pump you need the C block. A few Bs left the Louisville plant with the block made for the C.They just put a plate over the hole. What is the purpose of your question. Are you needing to replace on or the other. They did speed up the engine for the C then went to the Super C with larger bore that can be done with the B block.
