Re: Super C and H question.
Posted by tractorsam on February 12, 2009 at 14:56:48 from (142.177.21.2):
In Reply to: Super C and H question. posted by mike degroot on February 12, 2009 at 14:17:53:
First off your C-123 will likely fit although that doesn't seem like a serial number for one. You'll very likely need to swap flywheels as the power unit probably doesn't have provision for a pilot bearing. Also check out the hydraulic pump drive and water pump? I imagine you'll be able to swap them off your current engine though. In order to install the TA from a 300 you'll have to swap more or less the entire back end if you want the live PTO as well. If you just want the TA you might get away with just the central housing (someone else will have to verify that).
By any chance are you in Nova Scotia?
Hope that helped, Sam
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
