Re: Farmall A pinion and axle shafts
Posted by Haas on February 12, 2009 at 18:52:13 from (12.65.24.111):
In Reply to: Farmall A pinion and axle shafts posted by Danto on February 10, 2009 at 21:09:24:
You have to get the brake drum off the shaft before you can get the pinion out. The pinion won't go through the hole on the inside and I think there is a shoulder on the shaft anyway that will keep it from going to the inside. The reason you can't drive the shaft out of the brake drum is that the woodruff key that keys the drum to the shaft will catch on the bearing inner race preventing the shaft from coming out. So..you gotta get the drum off the shaft with a puller of some king.
