130 Transmission Rebuild
Posted by EZ on February 12, 2009 at 20:45:05 from (206.47.210.58):
Making some progress. The Trans is on the bench and stripped down to only the gears to remove. My new manual from Binder says to "remove the snap ring securing the reverse gear then slide the shaft out the rear of trans."
I do not see any snap ring on the reverse gear.
What I do see is a "pin" through the reverse gear holding it to the shaft. As far as I can tell this pin has to come out. There is no mention of it in the manual, plus I have the original TC-52 Parts book, it does not show the pin.
Any suggestions or experienced hands?
Thanks.
