Re: SC Fan Parts Don't Fit 200
Posted by Agpilot on February 13, 2009 at 09:19:05 from (206.146.78.170):
In Reply to: Re: SC Fan Parts Don't Fit 200 posted by Hugh MacKay on February 13, 2009 at 07:24:31:
Hi again Hugh: It may have been a simple need to clear the water pump and not much to do with any cooling factors required by the engine.
By the way, your comment:"You shut one down from heavy work and within seconds you hear boiling in the rad. I've run these ever since new, and they always worked that way." ... Hugh,you might be better off to allow some running time to cool off from heavy work or at least that seems to be a common suggestion. We always let our 1941 MD cool off after all heavy work from two family farms plus custom work for over a decade and never cracked the head. Cooling off after heavy work makes good common sence... for a man or machine... (adding a cold beer on extra hot day helps too)
I was just adding another possibility.. Bottom line,use whatever the factory sez. ag
