My own thought is that forcing grease in with a gun until it comes out the other side is the rule of thumb. On a new assembly and even later, there can still be air in there between the inlet and the outlet. That shouldn't be a problem as long as there is a reasonable amount of grease put in to start with. With time and the heat that comes from working it, the grease will get to where it needs to be.
If the new assembly was clean and dry, I'd grease it again after the first hot run and a little more frequently a few times at first after that. From there, the regular recommended schedule should do the trick.
That distributor would ordinarily only take a stroke or two once it's going right.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
