Re: M Carb Question
Posted by Too Far Gone on February 13, 2009 at 15:41:52 from (67.221.197.94):
In Reply to: Re: M Carb Question posted by rustyfarmall on February 13, 2009 at 13:42:18:
Ive already done everything You mentioned,and none of it makes any difference.The needle is shutting off.It doesnt leak out gas until You've tried starting it several times,then You will see the gasket getting wet,leakage around the front 2 bolts on the bowl,and seepage around the air/fuel screw.If the fuel level got that high it'd run out the suction side of the carb before it leaked out the top.It only shows up after You've been cranking awhile,and Im leaning towards a different carb.Thank You Guys for taking time to reply to me.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
