Re: Question about grease in Distributor housing
Posted by NDS on February 13, 2009 at 15:43:28 from (205.188.116.73):
In Reply to: Question about grease in Distributor housing posted by neblinc on February 13, 2009 at 09:12:50:
This is what operator manual says.......After every 500 hours of operation remove the grease plugs and insert lubrication fittings. Apply pressure-gun grease (chassis lubricant) to the distributor fitting until a small quanity comes out of the relief hole opposite the plug. Apply several strokes of the grease gun to the drive housing fitting.
Remove the distributor cap and the distributor rotor, and apply one or two drops of light engine oil to the felt in the hole at the end of the breaker cam.
